Looking for 30pin SIMMs
Postby mortovski on Sat Feb 04, 2017 5:36 am
Hi there,
I'm looking for some SIMM memory cards - the type that you would have found in a 486-type machine. It's actually for a vintage keyboard sampler, but they use the same kind.
I need 2 or 4 SIMM modules with the following specifications:
* 30pin non-composite
* Either 1, 4 or 16MB (can't be bigger than that)
* 80ns or faster access time
* Can be 8 or 9 bit configuration
Thanks!
Peter
mortovski
Re: Looking for 30pin SIMMs
Postby LS120 on Mon Feb 06, 2017 9:52 am
you will get only 256,512,1mb, 4mb in sim (30 pin) i have some 1mb and 256kb
Postby mortovski on Tue Feb 07, 2017 4:11 am
Thanks for that! The manual says that you can get up to 16MB in SIMMs, so I was just going off that. I'll DM you about the RAM.
Regards,
Peter
mortovski
Users browsing this forum: No registered users and 72 guests
