Hi All
Wanted:-
Atari 65xe,130XE,800Xe Faulty Keyboard for spares.
Or a complete machine that is faulty.
I have an Atari 800Xe with a faulty (Mechanical) # 6 key
The Cap plugs into a ? Slider that makes the contact BUT the Slider ? is Split and gets stuck as i push the key down.
I am trying to find somebody that has a Broken/faulty Atari 800xe keyboard to get just 1 ? slider thing.
I think that the Atari 65XE or the 130XE use the same keyboard.
You would have to be able to Post it to " Williamstown 3016 Victoria Australia "
Thanks Ray
