Boot up error on a Machintosh SE
Postby manuka on Tue Apr 23, 2013 1:55 pm
Hi I've just listed a Machintosh SE model # M5011 on Trademe. I get the following error on boot up 0000000E 00008000 and the drive light flashes red, I had a search but came up with no info on this error code. Any ideas anyone?
manuka
Re: Boot up error on a Machintosh SE
Postby tezza on Tue Apr 23, 2013 2:02 pm
You might have already found this but I'll post it anyway
http://support.apple.com/kb/TA46376
Does it help?
Postby tezza on Tue Apr 23, 2013 2:03 pm
As read from the document under the link above...
"Failed Data Bus test. The Z field indicated the bad bit(s) as a 32-bit mask for bits 0-31. This may indicate either a bad SIMM or data bus failure."
Postby manuka on Tue Apr 23, 2013 2:13 pm
Thanks Tezza, I'll add that info to the auction
manuka
Postby mrad01 on Tue Apr 23, 2013 2:22 pm
manuka wrote:Thanks Tezza, I'll add that info to the auction
On an SE, pulling out the RAM, cleaning the contacts/SIMM trays and carefully putting them back fixes 90% of these errors. I have sometimes needed to replace a couple of SIMMs - but rare.
