Since the C64C I just described in items available seems doa I figure it'd be nice to see the guts of the thing. After you take out the 3 screws underneath at the front what is the next step?
Sure is nothing like the lids on the apples lol
RonTurner wrote:I would start by googling a power supply pinout and testing the voltage at each pin with a multi-meter,
If its just the powersupply then your in luck, TM consists mainly of Spectrums, ZX-81's and C64 powersupplys and cables
Matt wrote:Thx for the suggestions. 1 other question:
Out with the dogs just now and suddenly occured to me that the black round thing on the psu is probably a fuse. Got back and had a look. The wire inside the glass is corroded but not broken. Is it a good idea to replace it? are they cheap at jaycar? (ok 2 questions:-)).
Users browsing this forum: No registered users and 88 guests
