DuoDisk spins endlessly / Won't load disks
Postby Gurner on Sat Feb 14, 2015 10:36 am
Background:
- PSU blew filter caps, DuoDisk was fine for the ten mins. it ran before this, loading several different disks.
NOW:
- Apple IIe beeps as normal, drive chatters, then just spins without reading.
- Have checked / cleaned heads – no gunk on read head.
Thanks for any help, been trying to get this IIe going for over a month now!
Gurner
Re: DuoDisk spins endlessly / Won't load disks
Postby Gurner on Sat Feb 14, 2015 10:39 am
PS: is there any code to boot from drive 2?
Gurner
Postby Gurner on Sat Feb 14, 2015 11:11 am
I did this below, it looks like the drive might ok as I do get the light and the chatter, but I still can't load anything.
"After you hit ctrl-Reset, type CALL -151 to get into the monitor
Then type C600L to get a listing of the Disk II firmware
A bad disk II firmware listing will have random code
Type Ctrl-C to get back to the applesoft prompt and type PR#6
If the disk drive rattles and the light comes on, then it is a bad
disk
If the computer hangs with no response from the drive and the firmware
code looked good then likely bad drive."
Gurner
Postby Gurner on Sat Feb 14, 2015 11:51 am
Also tried formatting a disk using this below – got DISK ERROR.
http://asciiexpress.net/diskserver/
Gurner
Postby Gurner on Sat Feb 14, 2015 12:18 pm
Pulled the DuoDisk apart and rigged it up so Drive 2 was talking to the IIe as Drive 1 – it works!
I don't need both drives working, but look like the wires are too short to simply swap the disks over...
Still no idea why Drive 1 isn't working – maybe the read head motor isn't working? Was working before the PSU died.
Gurner
Postby Gurner on Sat Feb 14, 2015 12:36 pm
Managed to get the wires to fit, and have installed Drive 2 to work permanently as Drive 1.
The purists might not like this approach too much, but I now have a working IIe!
Now to put all the DuoDisk case etc all back together and hope it still works... At least I know Drive 2 won't have had too much use over the years!
Gurner
Postby SpidersWeb on Sat Feb 14, 2015 5:05 pm
Not sure if it helps - but with regards to head cleaning, to get my drive to work correctly it took several runs with a disk cleaner - and the final winning clean involved an excessive amount of isopropyl on the disk cleaner surface (way more than I'd usually use).
Postby Gurner on Sat Feb 14, 2015 5:31 pm
Oh, OK – looks like the replacement drive has stopped reading now – I'll give it another clean.
Gurner
Postby Gurner on Sat Feb 14, 2015 5:47 pm
Thanks Spider's Web – you were right, it works again.
On my C64 FDD, if it looks clean after a dry cotton bud wiping, it works. Must be a bit touchier with the Apple II drives.
Oh bother, maybe that was all that was wrong with drive 1. I can swap them back another day and try!
Gurner
Postby Gurner on Sat Feb 14, 2015 8:55 pm
Bit of IIe eye candy for those who are interested. :)
Gurner
Postby Gibsaw on Mon Feb 16, 2015 10:14 am
Oh, god... the hours I spent on that game as a child. (twitching)
Users browsing this forum: No registered users and 148 guests
