kevman3d wrote:Tuning my ZX81 into the RF worked, but the picture was almost black on black.
arjoll wrote:Most ZX81s don't output the back porch - a reference level after the sync at the start of each line which sets black level. Older TVs don't mind, but anything new-ish (probably within the last 20 years!) will have problems. It's the output of the ULA, so a simple composite mod probably won't help, although it's such as well known problem there's a ton of info online.
kevman3d wrote:arjoll wrote:Most ZX81s don't output the back porch - a reference level after the sync at the start of each line which sets black level. Older TVs don't mind, but anything new-ish (probably within the last 20 years!) will have problems. It's the output of the ULA, so a simple composite mod probably won't help, although it's such as well known problem there's a ton of info online.
Just bought a new ZX81 membrane from RWAP, and obviously he suggested his ZXVid (also suggested the much cheaper ZX8CCB (not his product) though its been out of stock for a while) as they both correct the signal issues caused by the missing back porch. That said, A friend at work has an old 20" CRT that he says he'll (eventually) drop off so I'll test that when he gets around to it.
But thanks for that clarification - I was 'umming' over whether that mod would have helped, but obviously not. In a way I'm glad at this stage I haven't ripped the poor machine apart to try it just yet...
tezza wrote:Results must vary. With the mod I did, there was no problem with lack of contrast on the composite signal. It was perfect. Perhaps it depends on the monitor?
kevman3d wrote:tezza wrote:Results must vary. With the mod I did, there was no problem with lack of contrast on the composite signal. It was perfect. Perhaps it depends on the monitor?
Its also depends on what ULA is in the ZX81. Updated ULA's later on fixed the back porch issue - specifically the one I see from your photo's being a 210E, so that's why yours looks great.
Here's an interesting explanation (translated by google).
acsi wrote:The ZX-Vid is a great little unit. Costs a bit but is well worth it.
acsi wrote:I have also used the ZX8-CCB's in both ZX81's and a ZX80 and they give a real nice picture too.
Users browsing this forum: No registered users and 99 guests
