Wanting to buy or borrow Lisa 2/10 I/O and CPU cards
by mikemike690 » Wed Nov 30, 2016 7:03 pm
Hi guys, I recently acquired a Lisa 2/10 and I've tried to get It going and stable but haven't been able even with swapping around different cards which came with the unit, would any of you or someone you know be willing to lend or sell some please? Thanks in advance
mikemike690
Re: Wanting to buy or borrow Lisa 2/10 I/O and CPU cards
by tezza » Mon Dec 05, 2016 3:52 pm
Hi Mike,
Is it likely to be battery damage? What's the symptom in the Lisa?
by mikemike690 » Mon Dec 05, 2016 3:59 pm
tezza wrote:Hi Mike,
Hi Terry, nope no battery damage luckily, basically it shows a rolling screen and only sometimes like 1 out of 5 times actually boots properly, I've cleaned all the card edges and such but its still intermittent, so I think its a problem with the cards themselves. Thanks.
mikemike690
by tezza » Mon Dec 05, 2016 4:16 pm
Ok. Rolling screen. It's likely to be video card...maybe caps or perhaps just an adjustment.
There are so many things that can go wrong with these old machines. You are sure the boot failure is not due to the disk?
by mikemike690 » Mon Dec 05, 2016 4:59 pm
tezza wrote:Ok. Rolling screen. It's likely to be video card...maybe caps or perhaps just an adjustment.
Yeah ok, I've recapped the power supply but I haven't got to the video board just yet, yup definitely sure the boot failure has nothing to do with the disk because when it doesn't boot it just brings up horizontal lines and doesn't beep when just the CPU and IO card are inserted.
By the way, just checking that this is indeed a rolling screen? https://imgur.com/a/YzClA
Here are the lines that come up when not booting https://imgur.com/a/SscF6 or sometimes https://imgur.com/a/eldR4
mikemike690
by tezza » Mon Dec 05, 2016 5:20 pm
Right.
That does seem to be a rolling screen in that first set of images.
At least the fact it is intermittent would suggest some flaky connection or cap out of tolerance. In my experience if ICs fail they fail..full stop. Is it worse when the machine gets warm? I'm sure you would have reseated any socketed chips, yes?
There is a Lisa facebook site and also LisaList that has some Lisa gurus on it. Do you subscribe to those?
Unfortunately I only have one Lisa/2 10 CPU board and thats the one in my machine. I won't be sending that anywhere.
I'm guessing A fault in the lower RAM addresses could cause a fault like this too. Do you have two 512k RAM boards and if so have you tried swapping their positions?
by mikemike690 » Mon Dec 05, 2016 6:57 pm
tezza wrote:Right.
To be honest I haven't run the Lisa for more than 10 minutes but during that time it hadn't noticeably gotten worse, yup reseated all the chips. No I haven't subscribed to those but will do now, no problem I personally wouldn't send my only working board either just in case it got damaged, I've tried all the 4 RAM boards I've got which I believe are 512k but I don't know if they even are that. Thanks.
mikemike690
by mikemike690 » Wed Dec 07, 2016 10:41 am
Thanks Terry for telling me about that group, all good now!
mikemike690
Users browsing this forum: No registered users and 7 guests
