IBM 5155 repair
IBM 5155 repair
Postby Clym5 on Fri Dec 30, 2016 2:38 pm
I've managed to acquire an IBM 5155 a few weeks back from GCARD. Thought I'd post my findings and progress with fixing it.
It suffers from the ol' explodey tantalum capacitor illness, so far it's popped 6 of them. 2 on expansion cards, 3 on the motherboard and 1 on a floppy drive.
I've left the CRT unplugged while I work on it for now just as a safety precaution, so I don't know if it works as of yet.
The 5155 has only had an accumulative power on time of maybe 20 seconds over 10 on-off cycles since I got it.
First up is sorting out the power supply. It works, and puts out the right voltages. However, when I opened it up to preemptively change the line filter caps and electrolytic caps, I found the PCB was riveted onto the case. ImageImage
To save time, I'm thinking about taking out the old IBM PCB and fitting a newer ATX switchmode PSU board in there instead. I'd need to rummage up an ATX 1.X PSU as the newer 2.X ones don't have a -5v line, only a -12v line.
In terms of what expansions were in the 5155, there was the standard video card, a fully populated SixPakPlus, and two serial/parallel comms cards.
I can post links to higher res images if anyone wants. Cheers
Re: IBM 5155 repair
Postby Clym5 on Fri Dec 30, 2016 6:47 pm
I've decided to repair the old power supply with all new capacitors. I may still experiment with using an ATX 1.X or modifying an ATX 2.X power supply later though.
Re: IBM 5155 repair
Postby SpidersWeb on Sat Dec 31, 2016 7:49 pm
I recently got an IBM 5155 up and running too. Mine has had heavy use but in great condition with all the original books and carry case etc.
I had the same issues with tantalum capacitors.
I also noticed that the panels for drives or covers are slightly smaller than normal - worth noting if you ever planned to switch drives, replacements may need a little shave.
Re: IBM 5155 repair
Postby SpidersWeb on Sat Dec 31, 2016 7:52 pm
One quick other note though - make sure to order capacitors from reputable suppliers (element14, digikey etc).
For spare parts (quick repairs, not restorations) I ordered bulk caps from our friends selling over on aliexpress - and the labels are almost pointless lol
10uF - oh you mean 15uF? Oh look this one reads 11!
50% tolerance. ESR readings have all been good on them, but damn, can't solder in a single one without testing it first! (I guess it's not that critical in most situations where an electrolytic is used, but still)
Re: IBM 5155 repair
Postby Clym5 on Sun Jan 01, 2017 12:20 am
All the caps I've ordered have been through Element 14. Panasonic and Nichicon caps. I've had some fun times trying to figure out why something works worse after reacpping!
With the IBM 5155, there was a carry case and power cable (and assorted 3½" floppies?)
I'm going to have to put a new cable on the keyboard as the cable there has melted itself together and developed a layer of sticky residue on it.
And regarding removing tantalum caps, how strongly do you recommend replacing the blown ones? Or just remove them and leave it?
Re: IBM 5155 repair
Postby SpidersWeb on Sun Jan 01, 2017 10:08 am
For the tantalum caps that are just used as power filters (usually for the ISA bus) I generally leave them cut-off unless the system or a specific device is actually having a problem.
I try to avoid de-soldering components from those boards unless it's actually necessary.
Re: IBM 5155 repair
Postby Clym5 on Thu Jan 05, 2017 11:36 pm
Do you ever need to open a computer back up to remove tantalum capacitors that have failed after initial repair? Say, a few weeks or months after it being fixed? I really don't want to have to take out the motherboard from the 5155 again!
Currently waiting on capacitors for the power supply. ~20 that are getting replaced.
Re: IBM 5155 repair
Postby SpidersWeb on Fri Jan 06, 2017 9:57 am
To be honest, I often just bend them back and forward until they snap off - since 9 times out of 10 I wont replace them, it's worth it for that 1/10 times where I have to try and clean up the holes. So it's rare for me to remove the board from the case.***
There is no real way to be sure but for me I found they tend to generally occur around the same time and then whatever is left keeps working. However I've had two exceptions - IBM PS/2 Model 50Z and my 640KB IBM 5160, both needed reopening months or years later.
*** assumption being that they are not used as bypass caps for ICs (in which case I'd definitely replace, but I haven't had an issue with any that were used for bypass for some reason)
Re: IBM 5155 repair
Postby Clym5 on Sun Jan 15, 2017 9:32 pm
SpidersWeb wrote:To be honest, I often just bend them back and forward until they snap off
That's what I've done on two that failed, yeah. Luckily I've found the 5155 a dream to work on compared to the T3200SX and such so if I need to open it back up ever, not too much of a hassle.
Quick progress update, replaced the fan and recapped the whole power supply, even the caps that tested OK for ESR and capacitance. Still don't want to risk anything. Tested that it wouldn't go pop, and then plugged it into the 5155 motherboard so it'd see a load and start up. And it works! Motherboard didn't go pop, nor did the power supply. I even got the right POST beeps out of it!
Still yet to connect any drives or expansion cards/video to it.
Directly next to the 8088, there's a spare slot. I'm guessing a 8087 goes here? Would it be worth looking around for a 8087 for it?
Re: IBM 5155 repair
Postby Clym5 on Mon Jan 16, 2017 9:27 pm
Good news! I put the power supply all back together in its box, plugged the CRT in, motherboard in, and the CGA card in, and wala, zip nada. Had a quick test of the CGA card for dead tantalum caps, found one shorted, removed it and tried again.
And it works!
So now I'm going to test the expansion cards, and revive one of the floppy drives.
On a side note, replacing the filter capacitors in the power supply was a real hassle. The board is riveted to the case! Had to hacksaw it out as my drill wouldn't fit for the right angle to drill the rivets out. So now I've had to wrap the filter board in two layers of heatshrink tubing for insulation, and ziptie it all in place.
Re: IBM 5155 repair
Postby tezza on Tue Jan 17, 2017 2:17 pm
Good news and good pictures!
Re: IBM 5155 repair
Postby Clym5 on Tue Jan 17, 2017 5:15 pm
And of course, something's gotta go wrong. I'm not sure if it's user error or the computer, but when I run the Supersoft/Landmark diagnostics ROM, it doesn't run right. I've tried two PROMs, one old EPROM and a newer EEPROM, neither do much.
Most of the time it does what's in the picture. Empty text windows, and a blinking smiley face in the top-middle of the top-right window. Once or twice it's done something different but 90% of the time it's that.
I found a bad 4164 chip, as the computer was only counting 64kb of RAM. Now it sees the full 256k. Still getting the same fault after that too. I added in the floppy drives and controller, and with them, it won't even start the diagnostics ROM. It just spins the A drive forever and shows a blinking cursor.
EDIT: Tried a few different (E)EPROMs, and no change.
Some of the chips on this board run amazingly hot, but I don't have much time behind a broken x86, so I'm not sure what to expect. 8088 gets to 40c, and the NEC D8237AC5 DMA controller is around 60c. However, I guess since I can get into BASIC and pass the POST ram check that it must be working? Never heard of a half working IC apart from a SID chip before!
Re: IBM 5155 repair
Postby Clym5 on Thu Jan 19, 2017 11:04 pm
Figured it out. The stress of pulling the IC from the socket must've cracked the solder. Redid all the solder joints on U19 and U18 and it fixed it. Passed a few cycles of the diagnostic tests! Just chance that when I put the old U18 ROM back in, it all worked fine.
Next up: write two new 27(C)256 eproms with the latest BIOS for the board, clean, relube and fix both floppy drives. One of the drives went pop and the other likes to stay spinning (albeit slowly) all the time.
Re: IBM 5155 repair
Postby Clym5 on Sun Jan 22, 2017 10:21 pm
Investigating the warm chips some more, I found my 12v line is 12.32v. Seems a little high.. 5v is 5.013 so I'm happy with that. But the 8088 and 8237 are 5v chips, so it can't be the higher 12v rail causing them to get warm.
The 8237 gets to about 45c and the 8088 gets to 38c. Ambient temperature is around 22c. People have mentioned the 8088 runs cold, so I'm not too sure what to make of it for now.
Either way, I got the working floppy drive all cleaned up. Pressed new bearings into the spindle motor and main shaft and used silicone spray on the rails.
Re: IBM 5155 repair
Postby Clym5 on Wed Feb 01, 2017 12:34 am
I happened to pay a little more attention to a picture of a 5155/5160 motherboard picture on the internet and I noticed that this yellow wire isn't normal
http://i.imgur.com/bzenDWk.jpg
I'll look at pinouts a little later but I thought I'd put this here for other people to see/mull over too.
Users browsing this forum: No registered users and 97 guests
