Eprom Programming available
Postby Mark0x01 on Wed Jun 06, 2018 9:26 pm
If anyone in the Auckland area needs eproms programmed, I am happy to help out, having just added a Willem Programmer to my toolbox.
An upgrade on my ancient PCP-128 ISA bus Prom Blaster of 1985 vintage.
With no shortage of devices with parallel ports, and a need to cover back to 2716's and 25v vpp and a budget means vintage design rules.
I have just tried it out on a 2732A with immediate success.
Re: Eprom Programming available
Postby tezza on Wed Jun 06, 2018 10:05 pm
Good to know Mark,
Thanks!
Postby LS120 on Sun Jul 15, 2018 10:00 pm
what model did you get?
as they have a few different ones..
Postby Mark0x01 on Fri Jul 20, 2018 7:35 pm
Supposedly PCB5 OE 2018 - the parallel port version.
It seems to be one of the better ones, and I have tested the VPP power with a resistor as load to check for sag.
And it was within budget :D
I also splashed out on an M328 LCR, Diode, Capacitance, ESR & Transistor Tester kit.
I'm upgrading it to 0.1% resistors, as suggested on a few forums. It seems to work quite well.
Users browsing this forum: Baidu [Spider] and 38 guests
