Patrick wrote:I need a key switch because it is broken for the NEW LINE key (broken and glued, so that I think that replacement is the only solution). Do you know where I can get one ?
I need also two switch caps for the reset and cut buttons. Is this model OK? If not, do you know what is the correct model?
Patrick wrote:I just got an EACA Genie I, my first computer in the TRS-80 familly.
It seems to work, but my TV (10 years old) doesn't succeed to display UHF channel 36. I can see the message ready and the prompt when searching (and type also) but can't set the channel.
No matter, I will first make a composite cable.
I will post photographs soon.
Thanks for your help.
Users browsing this forum: No registered users and 261 guests
