disk drive belt
disk drive belt
Postby extra_anchovy on Tue Oct 18, 2011 6:16 pm
I've been wondering why my SF-7000 disk station wasn't working after I replaced the belt. the original one that came with it was almost disintegrated so I had to replace it. then I checked the tutorial on sc-3000.com and it says the belt must be 70mm x 3mm. measured the one I used, which was a famicom disk system drive belt and it was 100mm. anyone know where can I find a replacement belt, i'm having a bit of trouble locating one
extra_anchovy
Re: disk drive belt
Postby lizardb0y on Tue Oct 18, 2011 6:20 pm
Is it likely to be the same belt as the Amstrad and Spectrum 3" drives? There was a guy in the UK who was selling newly manufactured belts for these. I bought done off him 6 or 7 years ago. I'll look for his contact details for you.
Re: disk drive belt
Postby honestbob on Thu Jan 05, 2012 9:01 pm
I bought Spectrum drive belts from retrocomputershack on eBay about 12 months ago that worked nicely with the SF-7000. I think it was the equivalent of these:
http://www.ebay.com/itm/Sinclair-Spectr ... 3cb4668acd
http://www.ebay.com/itm/Sinclair-Spectr ... 3cb46686db
The tutorial on changing the belt on sc-3000.com is very good. You can't go too far wrong with that :)
Users browsing this forum: No registered users and 122 guests
