Some weird contraption
Postby tezza on Sat Dec 10, 2011 2:00 pm
Does anyone recognise this piece of archaic-looking hardware? I suspect it's a trainer or maybe it's a board which can be used for programming EPROMS?
It has a CPU I don't recognise. A 1082. I haven't Goggled it yet.
The handmade case makes the device look older than it is. 1984 is stamped on the board.
Re: Some weird contraption
Postby WelshWizard on Sat Dec 10, 2011 4:36 pm
Postby ZL2AOX on Sat Dec 10, 2011 5:39 pm
I haven't been able to identify the board but the CPU is an RCA 1802, as used in the COSMAC ELF and Super ELF, etc. If you have a mind to sell it, I would definitely be interested, just for the chip alone.
ZL2AOX
Postby Carcenomy on Sat Dec 10, 2011 6:02 pm
The CPU is an RCA 1802. Those things were used in space even... nice!
The chip up by the DIP switches is an RCA 1852 8-bit I/O controller.
So I'm suspecting, this board was either a microcontroller for something (hey, that's fine... that's what the MOS 6502 was designed for too) or was a trainer platform for the RCA 1802 CPUs. I'll do a bit more digging, see what I can find.
Postby tezza on Sun Dec 11, 2011 8:32 am
Thanks for those comments. I've now done some research. Yes, a RCA CDP1802 device possibly based on the ELF-range of computers.
As one person mentioned in another forum I posted this message to, 1984 is a bit late for a 1802 trainer. It's also a bit late for a "build-you-own-computer" kit when you could easily buy a C64 off the shelf. I'm puzzled as to what if would have been made and sold for. What was the purpose. Perhaps it was used to control something else, although the homemade case would suggest something of a hobbiest nature. The only thing that hints at a manufacture is “Lang 1984” and the small word “Commander” at the very bottom in the centre. I don’t know if it was made here in NZ or elsewhere? Tantalising lables like "BURNROM", READROM and RUNROM would suggest it could (or had) some role in play in burning EPROMS?
@ZL2AOX - Thanks, but I'll keep it for now. It may not be classic but it's certainly a curiosity. :) I notice 1802 chips are available on e-bay for collectors that want one (see ebay item 330550857955)
#welshwizard - If there was relevant info in that link you posted, I couldn't seem to find it?
Postby WelshWizard on Sun Dec 11, 2011 8:59 am
followed the link myself, not sure what I did but nothing like the site that was to have come up, will see if I can remember where the right link in my files and repost it, hopefully the right one this time.
It should be a link to a Lang Precision positioning system from about 1986, only seem to be able to find the 1994 model now.
Postby tezza on Sun Dec 11, 2011 9:28 am
Thanks for that. It does reveal something.
Although the document is not on the LANG Commander itself, it does mention it as a way to control the MCL precision positioning system.
This reveals a few possibilities...taken with a grain of salt given that the document is far more recent than my device.
    The device is not just a homebrew board
    This LANG Commander board was released by LANG GMBH & Co from Germany
    It may have been used as a controller for other instruments (the MCL PPS being one)
Trawling the web, this document seems to be the only thing on there that mentions the LANG Commander. It does have an email address though. I'll enquire.
Postby Carcenomy on Sun Dec 11, 2011 4:12 pm
Most likely situation by looking at it, is that it's a microcontroller that's been put in a homebrew chassis in order to use it as a microcomputer, or to simplify programming it.
Postby tezza on Mon Dec 12, 2011 9:18 am
Thanks for your help guys. I also posted a note on the International Vintage Computer Forums and got some feedback from there.
I've summarised what's been found/discussed in this blog entry. I'll update it if I find out more.
Postby matsondawson on Wed Dec 14, 2011 3:50 pm
Have you done a ROM dump?
Postby tezza on Wed Dec 14, 2011 4:18 pm
Not yet but it is on the "to do" list.
Postby tezza on Wed Dec 14, 2011 7:38 pm
Monitor ROM dumped. Looks like it contains code. Only 733 bytes though but that is probably par for the course for this kind of thing.
Postby tezza on Thu Jun 07, 2012 9:49 pm
I now know where this RCA CDP1802 (COSMAC) trainer of unknown origin comes from.
It's completely homegrown. From Wanganui no less. The (Dave) Lang Commander. :)
Postby SpidersWeb on Fri Jun 08, 2012 8:42 am
Ah that's an epic little piece of local history. Nice work.
I've found that knowing where a device/computer came from and having a little history just makes owning it so much more rewarding/satisfying.
Users browsing this forum: No registered users and 92 guests
