Atari 400p
Atari 400p
Postby acsi on Wed Apr 25, 2012 9:16 pm
OK so after receiving this from Molten Media this week I have opened it up and reconnected the speaker which came loose in transit and have just powered it up using a Vic20 2pin PSU as it didn't come with one. 9VAC PSU's are not stocked at DSE anymore (not a lot is).
The keyboard is the cherry one mentioned in another thread and the original 16k ram card seems to have been upgraded to 48k.
I have put a plug on the end of the coax and powered it up.
Red LED works that's a good sign as no exploding caps yet.
Just trying to tune it in. Seems to act as a good aerial anyway at picking up TV channels.
Yes I couldn't hope for a better picture from a 30+ year old modulator. And all the keys work although the 2 key is a bit dodgy.
Now I just need a basic cartridge and a PSU.
Re: Atari 400p
Postby tezza on Wed Apr 25, 2012 9:59 pm
Great to hear that its working!
I'm lucky in that when I got mine (from a TradeMe sale via e-waste day) I found a BASIC cartridge lodged in it! Mine booted up fine too, although it wasn't until later I discovered there was an issue. The SELECT and MENU buttons didn't work. At first I thought it was a Keyboard or keyboard ribbon fault but it turned out to be an IC in the end.
Anyway, enjoy the 400. They are built like tanks! Also a very interesting design if you even get the chance to take it apart. Essentially a BUS board with cards, including the one with the CPU.
Re: Atari 400p
Postby lizardb0y on Wed Apr 25, 2012 10:02 pm
tezza wrote:Anyway, enjoy the 400. They are built like tanks!
Built like tanks and look like spaceships. I've always liked the look of the 400 and 800 - a very memorable design.
Re: Atari 400p
Postby tezza on Wed Apr 25, 2012 10:33 pm
lizardb0y wrote:Built like tanks and look like spaceships. I've always liked the look of the 400 and 800 - a very memorable design.
Yes, I'm sure we can see the influence of "Star Wars" there. :) The movie came out in 1977.
Re: Atari 400p
Postby WelshWizard on Thu Apr 26, 2012 1:26 am
acsi wrote:OK so after receiving this from Molten Media this week I have opened it up and reconnected the speaker which came loose in transit and have just powered it up using a Vic20 2pin PSU as it didn't come with one. 9VAC PSU's are not stocked at DSE anymore (not a lot is).
If you goto atarimania.com I think they have the Basic cart as a download, so if some one has access to a burn you could easily burn a chip, find an old ET phone home cart ridge ( the cheapest one on the market you should find one for about a $1) easy swop and you will have basic,
Re: Atari 400p
Postby Carcenomy on Thu Apr 26, 2012 7:03 pm
Of course ET Phone Home is cheap, it was an abortion of a game! :lol:
Re: Atari 400p
Postby WelshWizard on Thu Apr 26, 2012 8:06 pm
Carcenomy wrote:Of course ET Phone Home is cheap, it was an abortion of a game! :lol:
I think every one knows about the crap game, but you would be amazed how many are out there, just waiting for a new ROM chip to make them useful.
That's why its such a good candidate for using as a cartridge case, cheaper than buying a cartridge to take a new ROM.
Re: Atari 400p
Postby tezza on Thu Apr 26, 2012 8:21 pm
Yes, that's a good idea. If you have a ROM burner it shouldn't be too difficult to replace the cartridge ROM with an EPROM replacement...containing BASIC for example.
Re: Atari 400p
Postby acsi on Thu Apr 26, 2012 9:51 pm
Unfortunately I don't have access to a burner but I have ordered a basic cartridge as well as a SIO2SD.
Just got the psu to get yet as jaycar don't have one big enough. I may have to make one myself as I have a suitable transformer just need a case for it.
Re: Atari 400p
Postby SpidersWeb on Fri Apr 27, 2012 8:20 am
What current rating do you need? I found a 9VAC adaptor last night - haven't checked voltage but unless you need 2 amps or something I could test it.
Re: Atari 400p
Postby acsi on Fri Apr 27, 2012 1:57 pm
From what I can find the smallest Atari made was 1.7A 15VA.
Have only been able to find a max of 1A locally.
Re: Atari 400p
Postby WelshWizard on Fri Apr 27, 2012 8:37 pm
I think you will find Jaycar has what you need.
https://secure.vividcluster.crox.net.au ... rm=CAT2#12
Re: Atari 400p
Postby WelshWizard on Tue May 01, 2012 11:10 pm
http://www.ebay.co.uk/itm/atari-400-XL- ... 3a73c2613c
for a Basic cart at 5 quid
http://www.ebay.co.uk/itm/atari-400-XL- ... 3a73c26135
10 quid start
same seller, so if asked he may ship to NZ and if he does should only be about 3 quid.
Re: Atari 400p
Postby acsi on Wed May 02, 2012 4:27 pm
Thanks. I have one on the way. Cost was about $us8.
Havent had a chance to build the psu yet. Hopefully on Friday.
Re: Atari 400p
Postby Gibsaw on Wed May 02, 2012 8:17 pm
acsi wrote:9VAC PSU's are not stocked at DSE anymore (not a lot is)..
Yep... don't remember where I heard it, but they're abandoning the pretence as an "electronics" store and explicitly going out of components... and closing quite a few stores. (Apparently the namesake founder "Dick Smith" is infuriated at the mismanagement by woolworths.)
Users browsing this forum: No registered users and 117 guests
