SpidersWeb wrote:If the new battery doesn't fix it, I'm guessing the problem is likely the "unusually clean area around capacitors". The board is covered in dust except magically around a big area of capacitors - so it may need a bath. No other visible faults stick out.
SpidersWeb wrote:I just wish my nearby DSE wasn't a Noel Leemings in disguise :/
Gibsaw wrote:Then, given that those caps are now minus their electrolytes... It sounds like you have some caps to look at replacing.
Gibsaw wrote:First things first... if there is a screw missing, make sure it's not floating around. (although if it is, the damage done will be too late.)
recycled wrote:Gibsaw wrote:First things first... if there is a screw missing, make sure it's not floating around. (although if it is, the damage done will be too late.)
Spot the guy who's never had to do work on a real Mac! ;o).
What monitor are you using? An apple one or a PC VGA screen with an adapter? Are you starting up with the VRAM SIMM present? Are the ROMS in the correct sockets? (In my LC2 they are labelled 341-0473 in socket UB2 LL to 341-0476 in UE2 HH, someone may have tried the old 'pull and re-insert the ROMs trick' and messed that one up). Unplug the HDD and the floppy - does anything flash on the screen when you power it up like this? You should also try a PRAM reset now you have a new battery - the old one may have just had enough to keep a bit or two floating.
Gibsaw wrote:recycled wrote:Gibsaw wrote:First things first... if there is a screw missing, make sure it's not floating around. (although if it is, the damage done will be too late.)
How so?
recycled wrote:A 'REAL' mac is a joy to work with as EVERYTHING clips together. The first case design to use screws was the Quadra 800, which earned it the first 'Road Apple' honor.
Users browsing this forum: Majestic-12 [Bot] and 10 guests
