Does anyone know the symtom here as it gives me no errors at all. Just a endless loop
Thanks
tezza wrote:Sounds serious. Unfortunately I've never seen this symptom before. I wonder if running DART corrupted the boot tracks somehow.
Does the machine boot normally just with a floppy? If so, then at least the Lisa is ok.
I didn't have any luck getting my profile working. It did boot to MacWorks a few random times but 99% of the time it just throws up an undefined error.
I do have one of these X/Profile cards so I can at least pretend the drive is going. It's too quite for the real deal though :)
Divix798 wrote:I have tried many many system disks fom images from mothership, Raul's and your two files for a Macworks XL 2.0 I think. The "boot" disk goes to white screen then gives me a read error. One Macworks system from mothership (not plus) disk almost worked and went to the last title screen(Welcome to Macworks) but gave me a bomb error:(! In the service manual it says to enter a system disk at flahing icon.
I think I need A "Macworks Plus disk" since thats the OS im using maybe? The one I found on mothership does not work and I cant get Disk copy4.2 to see it!. Does it work for anyone else in Disc copy4.2? Im hoping a fresh install in the Lisa will help but finding software has been a task. If you know any sources that I dont know that would be great. There is Macworks Plus II on ebay for a very large sum
tezza wrote:Anyone else on the forum have a working Lisa?
tezza wrote:Divix798 wrote:I have tried many many system disks fom images from mothership, Raul's and your two files for a Macworks XL 2.0 I think. The "boot" disk goes to white screen then gives me a read error. One Macworks system from mothership (not plus) disk almost worked and went to the last title screen(Welcome to Macworks) but gave me a bomb error:(! In the service manual it says to enter a system disk at flahing icon.
I also found it very hard to get good copies of boot and installation disks from the web. Some worked and some didn't. Those ones on my Lisa disk image page worked for me.
If you get an error with the Macworks emulator disk image from my site then either the images have not been written to real disks properly or the floppy drive is faulty. You might need to sort this out before trying to reinstall on the ProFile. Yes, there are several versions of the Mac-like Lisa OSs and if you want to repair the software in the Lisa you'll need the right one.
I see you've been posting on the (International) vintage computer forums too. That's a good idea as there are a limited number of Lisa users here in New Zealand.
Corestore wrote:tezza wrote:Anyone else on the forum have a working Lisa?
Yep. I think I even unboxed it.
Also have a couple of ?dead? Profiles, a couple more Lizae, and one of those dohickeys that replaces the widget drive with a CF card...!
Mike
Mike
Divix798 wrote:Hey Tez, I think my floppy drive on my Lisa 2/10 is faulty. I aquired a few genuine Macworks Disks and they also are giving me disk errors. Once every 20th time I try the boot disk it finally will see it. When I enter the system disk it gives me a sad mac error. This drive had been cleaned out and dust free. I have no experiance to service this drive and will propably just find a used replacement. Thanks again
tezza wrote:Divix798 wrote:Hey Tez, I think my floppy drive on my Lisa 2/10 is faulty. I aquired a few genuine Macworks Disks and they also are giving me disk errors. Once every 20th time I try the boot disk it finally will see it. When I enter the system disk it gives me a sad mac error. This drive had been cleaned out and dust free. I have no experiance to service this drive and will propably just find a used replacement. Thanks again
Yes, I've had a faulty Lisa floppy drive before. I'd cleaned it, it was lubed, it made all the right noises....and once in a blue moon it would read the disk but often not. I tried to fix it but ended up getting another one in the end.
There is nothing as frustrating as unreliable disk drives.
Don't discount the floppy controller though. It is possible it's that. Hopefully not.
Divix798 wrote:One last chance to salvage the floppy drive I cleaned the stepper motor shaft with WD40 with a Q tip. I was thinking maybe the head was lagging from the old grease on the cork screw shaft. But now the drive works every time!
arjoll wrote:Divix798 wrote:One last chance to salvage the floppy drive I cleaned the stepper motor shaft with WD40 with a Q tip. I was thinking maybe the head was lagging from the old grease on the cork screw shaft. But now the drive works every time!
Great news - but remember WD40 will only be a temporary fix. You'll be best to use a proper lubricant now that you've found the issue - I'd try a tiny bit of silicon grease.
Divix798 wrote:Yes I used Tri-flow synthetic grease that is a very light clear lubricant. Ill try a Silicon grease if that is not recommended.
Users browsing this forum: No registered users and 165 guests
