Tech question and answer – 1:
1. WiFi is not working in my laptop, what is the solution?
Answer: First uninstall the WiFi device software from your laptop, Download a latest version from the laptop manufacturer website and install it.
If this problem still occurs, then, it seems that there is a problem of WiFi device. You may need to contact the customer care.
2. How to remove shortcut virus from PC?
Answer: Shortcut virus is a virus which is annoying more and more. It generally creates a disgusting problem. To get rid from it, you can use latest version of updated antivirus. Also you use latest version of malware bytes.
Can download malware bytes from here:
https://www.malwarebytes.org/
3. How can I recover deleted data?
Ans : If you accidently delete data, then you can still recover that data, though sometimes these data may be corrupted. You can use data recovery software to recover data. There are so many software you can find online to recover data like Recover My Files, Easy Data Recovery, Media Rescue Pro, Photo Rescue pro etc. You can also get help from the search engine to get the information about data recovery.
4. How can I open ZIP or RAR file?
Ans : Generally some files we download from the internet are packed as rar or ZIP. We need to open or extract files from it. To do this we need to install WinRAR or winZIP software in our PC.
Also if you are using windows 7 or later version then, you can download and install 7 ZIP.
You can download WinRAR from here:
http://www.rarlab.com/download.htm
5. How to secure a folder in PC?
Ans : Sometimes it is needed to secure one or more folder in a PC. Because some folder contains important information or personal information. There are so many software through which you can secure your folder in PC. Some of them are folder lock, hide my folder, Password folder, PC security etc. For more this types of software you can search in the search engines.
You can download folder lock from here:
http://download.cnet.com/Folder-Lock/30 ... 63343.html
