Amstrad? & other keyboards...
Postby RdM on Sat Apr 16, 2016 2:38 pm
Now sorting through saved old keyboards...
Apart from the IBM/Lexmark Model M keyboard I have on TradeMe, I've found I also have some other have some XT & AT keyboards, and a couple that are switchable, also mechanical, with quite nice Alps switches.
The latter might go on TradeMe at some point.
But there's also this oddball Amstrad keyboard, which perhaps no-one will want, but before it potentially goes to TradeMe - or landfill?
I think (fairly sure, from memory) it came from one of these:
http://www.computinghistory.org.uk/det/1264/Amstrad-PC2286-40/
so likely AT, although it also looks quite like this as well
http://www.computinghistory.org.uk/det/16138/Amstrad-PC2086-S/
Any interest?
Thanks!
RdM
Re: Amstrad? & other keyboards...
Postby ZL2AOX on Sat Apr 16, 2016 3:38 pm
I'm interested. I have a PC2086 that it could go with.
ZL2AOX
Postby RdM on Sat Apr 16, 2016 5:52 pm
OK;- (another one that might have gone on TM, but good to have a quick answer!)
I'm pretty certain it'll be working - I remember it was the PC that had died (a colleague's at the time).
Maybe, with their own proprietary keyboard codes, they didn't distinguish between XT & AT PC's?
Good to see it go to a good home (& fellow ham, although I'm not on air!).
A little bit more of a laborious packaging job, but it will easily be under 5kg, http://tinyurl.com/nzpost-track so bare postage cost $8.50.
Again, any small donation toward packing & a trip to the PO gratefully accepted! :D
But I'm happy for you to have it! (I wouldn't have put much on it for TM, anyway.)
I will say though that I only gave it a fairly cursory wipe-down for the TM photos, it was mostly just very dusty!
The clips to separate looked a bit hard to get off at once &or without breaking, to give a good clean.
Ross ZL1RDM (was ZL1TND as a schoolboy back in late '60's, but let it lapse.)
RdM
Users browsing this forum: No registered users and 45 guests
