8087 co-processors.
8087 co-processors.
Postby RdM on Sat Apr 16, 2016 2:46 pm
I have two of these, one labelled C8087-2 and the other C8087-3
No pics at present. Could take some if wanted.
Pins have been stuck in (one on each side!) a small piece of ant-static foam for years.
Pretty sure they came from working XT machines (the old Corona desktops). :(
Slight bubbling of the gold square, and some tarnish or corrosion showing on the leg mounts, although gold-plated - perhaps it was porous enough to allow some atmospheric interaction?
Thought I'd offer here to gauge interest, before perhaps putting them on TM.
Thanks!
RdM
Re: 8087 co-processors.
Postby ZL2AOX on Sat Apr 16, 2016 3:37 pm
I'm interested :)
ZL2AOX
Postby SpidersWeb on Sat Apr 16, 2016 3:45 pm
I'm interested as well, have quite a few XT machines here that could use a bit of a boost in SimCity and Lotus 123 :)
Postby RdM on Sat Apr 16, 2016 5:28 pm
OK, here they are...
I've made no attempt to clean them up - probably they would easily enough though.
C8087-3 looks worse, but the actual pins look OK. Hopefully it's just on the surface.
(I see there's a slightly bent one on C8087-2.)
Hmm, perhaps I should have listed them on TM after all! :shock:
However, I can't guarantee that they're working, but as I say I think there's a fair chance they will.
OK, how do we do this? PM me your details, for a start...
I could send as a letter, probably max thickness, to allow for padding,
https://www.nzpost.co.nz/personal/sending-within-nz/letters-documents/standard-post
or say in the smallest pre-paid padded bag, to which tracking could be added.
https://www.nzpost.co.nz/personal/sendi ... ange-works
While I'm happy to see them go to good homes, any rounding-up of postage &or donation toward packing and a trip to the PO would be appreciated... :D
One problem might be finding another piece of foam;- they're back to back at the moment!
RdM
Postby RdM on Wed Apr 20, 2016 6:48 pm
OK
Cleaned up a bit, isopropanol & and an old genuine bristle French toothbrush (rare now) employed to help clean the upper edges...
It seems it was just colourful grime ...
And fine cotton cloth, a bit of a wipe-down.
Not perfect, nowhere near it, but perhaps an improvement
On foil, under lights.
Since then, I've thought;- do I have another XT PC left; that I could test these in?
- yes, a Zenith Supersport ZFL-184-01, an XT laptop that served well earlier... the printed book manual I have shows me that there is an option 8087 slot, easily accessed; I've checked and seen that it's empty.
Question is, if it goes again after all these years, which it might;- I had had fun even up to MSDOS6.2 with it, as I recall;- and even Win95 dos;-
(Update it does go, still!)
How can I check that an installed 8087 co=processor is installed, under DOS? Can it be shown existing and working, I ask myself, and search.
Apparently so, with MSD.EXE Version 2.11 (Microsoft Diagnostics Utility). So I've downloaded that. But will need to organise another DOS PC to copy.
Or make up a Laplink cable again, or find my old one... it's been a while since I was back in this realm!
And, I've learned more about 8087s, and that the Zenith specified an 8087-2 - http://terminus.tzo.com/zds/faq.htm#faq2
So I'm going to hold off on the offer until I can prove that they're recognised. Which means also building/configuring a DOS PC again.
The most likely (and slowest) candidate I have now (apart from the said Zenith & the possible Corona luggables) is a Compaq DX2-66 (or DX4-100).
Thanks for the PM, ZL2AOX - the Amiga keyboard is certainly yours, and for the note of interest, Spiderweb.
Bear with me while I venture back & check them out...
For some reason Happiness Stan , Ogden's Nut Gone Flake comes to mind...
Cheers! ~ Ross.
RdM
Postby SpidersWeb on Wed Apr 20, 2016 11:20 pm
Generally on a PC there will be a configuration chip to enable the 8087.
If the switch is set, and the co-processor is faulty or missing, it should generate an error.
Postby ZL2AOX on Wed Jun 22, 2016 12:57 pm
What is happening about these?
ZL2AOX
Users browsing this forum: No registered users and 64 guests
