Dot matrix printers
Dot matrix printers
Postby tezza on Sat Oct 04, 2014 9:36 pm
I've run out of computers so covering some peripherals.
Remembering dot-matrix printers. Educational for younger people and maybe nostalgic for the rest of us?
http://youtu.be/UWM2OZGF8v0
Re: Dot matrix printers
Postby SpidersWeb on Thu Oct 09, 2014 6:50 am
Great video as always. That screech is quite characteristic of many offices, it's a noise I hate but at the same time brings back a lot of memories.
I have 3 dot matrix printers that all function correctly but finding replacement ribbons has been infuriating for me (Star LC series). I'll get "new + sealed" items sent over, open them up and install and they're dry! Some luck with treating them, WD40 or similar, but ended up just getting frustrated. Using a 1989 HP Deskjet Plus now - can actually still buy the cartridges new from HP which include the nozzles, so I'm fitting a 2014 head/ink to a 1989 printer and I think that's pretty awesome.
Postby Gibsaw on Thu Oct 09, 2014 12:20 pm
Must be possible to find out what the correct solvent is for them?
Postby SpidersWeb on Thu Oct 09, 2014 12:40 pm
Gibsaw wrote:Must be possible to find out what the correct solvent is for them?
Yep. I think it's a mix of glycol + alcohol from memory (could be wrong) - WD40 does the trick but I don't think I let it saturate in to the ribbon for long enough. "Infuriating" was probably the wrong word, just a little frustrated.
Postby Carcenomy on Wed Oct 15, 2014 10:57 am
OKI Microline. It's the only way to go in a dottie these days, they're still available new and hell... the 391 Turbo works in DOS right through to Windows 8.1! :) Ribbons are easy meal too. AFAIK the Microline has been around since back in the day too... is a brand new device using the same pattern as the 80s okay or cheating? :)
Users browsing this forum: No registered users and 35 guests
