Finding the right voltage?
Postby Clym5 on Mon Sep 14, 2015 7:18 pm
Hey all,
I recently acquired a Datalogic SC8000 controller. Ex Air NZ I'm lead to believe. It needs a junction box to break out the connector on the bottom, which handles power, Ethernet and a few other things but I don't have the junction box (someone I know might have it though).
Does anyone here know a good way to determine input voltage for a motherboard? The specs say 24v but that's into the junction box. It takes the old style PC motherboard plug but with 3 red wires, one blank, and then two black.
Edit: removed image. It wasn't the same.
I'll put some pictures up soon as it's a really interesting device. Also, seems quite expensive...
http://www.ebay.com/itm/Datalogic-SC800 ... 1259654305
http://www.ebay.com/itm/DATALOGIC-SC800 ... 0749785959
Re: Finding the right voltage?
Postby TheM on Wed Sep 16, 2015 3:23 pm
Looks like old style PC power supply connectors:
http://www.playtool.com/pages/psuconnec ... html#oldpc
TheM
Postby Clym5 on Wed Sep 16, 2015 4:28 pm
On closer inspection, it doesn't physically match any of them.
http://imgur.com/a/CdNgU
Since this is an industrial board with no documentation that I can find (for the motherboard), I don't really want to try the magic smoke method!
Postby SpidersWeb on Thu Sep 17, 2015 9:54 am
Follow a trace from the positive rail until you find components you can identify, and check what their ranges are. Eventually you'll come to a conclusion.
The breakout board looks like it may just pass the power through, and on the motherboard itself I see things like chokes and big caps - which makes me think it basically has a mini power supply on the board itself - so I wouldn't be completely surprised if it actually does take 24V and splits/regulates this to +12/+5/0/-12 on the motherboard.
But yeah, follow traces, look up parts. Capacitor ratings *can* help for evidence purposes too, generally a manufacturer wont use a big 50V eletrolytic cap on a 5V line for example. Good idea to check first, because chips don't like 24V generally lol
Users browsing this forum: No registered users and 17 guests
