Can anyone recommend an sdcard system for an Apple 2?
by matsondawson » Sun Sep 23, 2018 11:06 pm
I spent ages tonight trying to work out why my Apple 2 wouldn't load files properly.
Turns out on the old 2's you had to load dos first.
Anyway who want's to screw around with dirty disk drives?
Re: Can anyone recommend an sdcard system for an Apple 2?
by tezza » Mon Sep 24, 2018 8:50 am
This card is pretty good Matt, although it's not cheap!
https://www.classic-computers.org.nz/bl ... fa3000.htm
by glc » Mon Sep 24, 2018 12:18 pm
I have one of these I get from trademe
http://www.a2heaven.com/webshop/index.p ... uct_id=124
Unfortunately my IIe is dead at the moment so unable to use it
It doesn't suit a IIgs
hopefully will get to use it on my newly aquired IIc :-)
I can bring it round next time i see you to have a play
cheers
glc
by matsondawson » Mon Sep 24, 2018 6:59 pm
Wow they all cost a fair bit, but that's fair enough.
I wonder if there's one I can parallel with a drive, such that the drive makes the right noises, but the actual code loads off an sdcard.
I'm tempted to just build one myself.
There's a fair bit of code online about this.
What would be cool is if it could connect to home network via WIFI and you could go to a page on a tablet and select the disks you want to insert.
by glc » Mon Sep 24, 2018 7:55 pm
glc
Users browsing this forum: No registered users and 34 guests
