looking for a 800kb system disk or a way to create one
Postby gkmaia on Sun May 24, 2020 5:50 pm
I got 3 of these old macs. A MacSE with a hardrive and functional floppies and boots fine.
A Mac Plus that needs a floppy to boot but my floppy went caputz today...
Is there a way I can create a new 800kb boot disk by using my functional Mac SE?
If not, would anyone be able to sell me a boot disk and some utilities to clone the boot disk?
gkmaia
Re: looking for a 800kb system disk or a way to create one
Postby entomos on Sat Jul 11, 2020 4:07 pm
You can but you will need to get the disk image across to the SE, do you know if your SE is running a Superdrive?
Do you have a new Mac with a USB drive? Because the Superdrive allows you to write and read a 1.44 disk as well as the variable speed 800k disks.
If you haven't sorted it yet I should be able to write you out a few and drop them in an envelope.
entomos
Postby gkmaia on Sat Jul 11, 2020 5:54 pm
I finally managed to do it.
I got saved the files and images using my old pc, then wrote the disks using my LCII. It worked just fine.
To generate boot disks to my SE/Classics and LC I am just writing straight from my PC's omnidisk.
gkmaia
Users browsing this forum: No registered users and 53 guests
