Hi
Hi
Postby entomos on Wed Dec 17, 2014 7:47 pm
I remember using a ZX Spectrum and a C64 at friends places but my family brought an Amiga 500.
Later I really wanted the A600 due to the footprint and the A1200 but I never could afford them.
It took me a long time to get rid of the Amiga 500 but did so in a move around 2009, the end of 2010 I was sitting annoyed in front of Cubase wondering why I couldn't do a simple task that I remembered Octamed could (ok so ones a tracker and the other is DAW).
This lead me to getting an A1200 off Trademe (which came with a A500 as well) in early 2011 and it went from there. I have been reading over this forum for a couple of years now and thought I should join.
Luckily I kept all my old disks and still had an older PC which support 2 Floppy drives so I could use Disk2FDI to read them in. They had suffered through damp flats etc, So killed a lot of cheap PC drives in the process but got about a 80 to 90 percent success rate in reading them in.
I currently have
Amiga 1200 running an ACA1230, IDE to CF Card and a Indivision AGA Mk2
Amiga 600, 1 MB ram in the trapdoor, 4 MB CPU clip on ram,IDE CF Card and a Indivision ECS
Amiga 500, 512 KB in the trapdoor, Gotek Floppy to USB to replace the Floppy drive
C64C with a Kerberos Midi Flash Interface
And a few consoles
entomos
Re: Hi
Postby SpidersWeb on Thu Dec 18, 2014 7:57 am
Welcome aboard :) Nice to have another local around too.
Most of my stuff is PC, but have managed to pick up a VIC20, C64C, and Amiga 2000 from local second hand stores (also have a couple of other C64C's from other sources).
Damp media is always a pain, if you end up doing it again you can get floppy drive cleaning kits - I keep a few around in both formats ready to go in (just takes 15-30 seconds with a few drops of isopropyl). Although PC 3.5" drives are pretty disposable.
Re: Hi
Postby tezza on Thu Dec 18, 2014 8:03 am
Welcome to the forums entomos!
Re: Hi
Postby entomos on Thu Dec 18, 2014 9:23 am
Thanks Spiders Web and tezza,
On the floppy disks I was reading in, I had picked up 20 PC Floppy drives at $2 a piece and was cleaning the drives with isopropyl as I went, and I am sure I knock the alinement out of a few of them as I was cleaning them.
Some of the disks were coated in mold so it was very hard on the drives and I ended up cleaning some of the disks directly (for a last ditch read effort) and this yielded better results.
If you do know a supplier for 3.5" cleaning kits I would be keen on getting one.
entomos
Re: Hi
Postby tezza on Thu Dec 18, 2014 11:15 am
entomos wrote:If you do know a supplier for 3.5" cleaning kits I would be keen on getting one.
Yes, mouldy disks can be hard on drives. I don't every try if I suspect a disk is mouldy. 5.25 inch ones can be removed from the jacket and washed.
No, I don't know a supplier for these 3.5 inch cleaning kits. I managed to score one..I think from e-bay.
Re: Hi
Postby SpidersWeb on Thu Dec 18, 2014 5:12 pm
I got one off trademe a while back, but most of mine are from ebay (one even came from Russia with a bunch of random floppies with Russian labels). That's only for cleaning the drives though.
For disks where you can't remove the media (without damaging the jacket) I have found if you're very very patient, you can wipe the media, then rotate a litlte, then repeat until there is nothing visible on the surface. It's quite time consuming though.
Re: Hi
Postby entomos on Thu Dec 18, 2014 9:25 pm
Thanks again, Will hit up Ebay but wondered about them shipping items with isopropyl in it.
Spiders Web, that is how I cleaned about 40 disks, just watched a movie and turned them slowing wiping them down.
It worked really well. I assume they won't last once that is done to them but I got my old data off.
entomos
Return to Introductions
Users browsing this forum: Baidu [Spider] and 13 guests
